Cleaning cartrdiges not fixing prints
OM2
UK, London
Canon MP640: I've done several deep head cleans but my colours are still printing with streaks
Does this indicate a a fault with the ink carts or the print head?
My printer is still under Canon warranty - should I request for the problem to be fixed?
I would have to incur the charge of sending the printer to their approved repair centre
Thanks
Omar
Hi Omar
You dont give us enough information to give you a definitive answer.
Can you please post a nozzle check and more info like when did this problem start are you refilling using OEMs which method etc.
Doing continual deep head cleans does nothing at all to solve your print problem except waste your ink
a standard clean is usually sufficient to clear most clogs.
It may not be your print head thats at fault so don't do any more printing other than nozzle checks till it's resolved.
OM2
UK, London
@thehat, thanks for the reply
see following for a nozzle check print: http://i.imgur.com/Yhl4Q.jpg
i refill using german method and inks *always* purchased from octoink
i noticed the problem 2 weeks ago - this was the same time i refilled funnily enough
too much of a coincidence? i can only confirm this by thinking back
i didn't bother about it until a week ago
i've printed maybe 10 times on maybe 50 sheets so far
have stopped printing following ur comments
let me know what u think
thanks
OK Omar,
To be blunt and honest I think your print head is dead bang down the hole.
You could however continue to use it for just text printing but even then that might kill your logic board after a time too.
The main problem with a Canon print head is that if it suffers from partial or no ink flow through the print head
for a short period of time then it tend to heat up and fry the little ink nozzles.
Thats why it is imperative to stop all printing till you can diagnose the problem and put it right again
and in your case you didnt spot it in time so thats the reason I suspect its permanently damaged.
In many cases a clog can accrue from leaving your printer unused for some time or not having all of the cartridges fitted
in the print head and the inlets dry out or usually even a poorly refilled cartridge.
If you have a set of original Canon cartridges you may be able to send them back with the print head and not the whole printer,
depending on which Canon service centre you use, saying that Canon service is usually crap anyway so dont hold your breath sorry.. :(
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
If you haven't given the printhead a soak in windex or equal, you ought to give it a try. I would.
Wayne
OM2
UK, London
thanks for the replies guys
i'm going to call canon on monday and ask for a warranty repair
from past experience i know that they will want me to send in the whole damn printer
this will cost me just under 10
