- Jan 18, 2010
- Location
- Residing in Wicklow Ireland
- Now have 3 Ender-3 V3 Plus SE/
Here are a few undeniable facts.
If you look at the Pic below, it’s a simple drawing of a Canon Print Head and Cartridge which clearly shows why a CISS won’t work effectively on a Canon printer.
click to enlarge.
The ink nipple on the print head, where the cartridge normally sits, makes firm contact with the recessed sponge inside the cartridge outlet, and that connection and seal is more than adequate to provide a continuous supply of ink to the print head.
Now add a CISS to that printer and everything changes, because the CISS setup cannot maintain the constant vacuum needed between the cartridge and the rubber gasket and so it has to constantly play catch up while under load.
The constant vibration created by the CISS tubing breaks the vacuum seal with every stroke back/fourth, but as it prints the reservoir does provide sufficient ink to compensate for this loss, but not while the printer is idle, that’s when the gremlins can begin to creep in.
Two separate things can now happen slowly or quickly, depending on the installation, the cartridge can ingest air from the broken seal and this can allow the ink to travel back to the reservoir, which then will need re-priming the next day before commencing any print jobs.
Alternatively with no vacuum and the seal compromised the ink can continuously flow to the cartridge, and out through the broken seal which can slowly flood into the print head till the reservoir bottles empty, it’s no joke because either of the above scenarios can take place in a CISS printer near you..
click to enlarge.The ink nipple on the print head, where the cartridge normally sits, makes firm contact with the recessed sponge inside the cartridge outlet, and that connection and seal is more than adequate to provide a continuous supply of ink to the print head.
