Canon PGI-5 Pigmented Ink -Can I use a cheaper dye based ink?
nnicko
Hi! I have a Canon PIXMA MP830 which has four dye based ink cartidges (including black) and a large black pigmented ink (PGI-5).
Can use cheaper non-OEM dye based black in that slot or will it print poorly, screw up the nozzle head or cause other problems? I'd give Canon a call but it's obvious what their answer would be.
Thanks!!! :)
You can do so without any noticable problems. However if you want fade and smear resistant text printouts go for the pigmented ink for the PGI-5Bk.
To limpid inks can cause smearing during printing and bleeding, so watch out for very cheap inks.
