Hello there!
Recently, when I was printing I started to notice that my printer was not printing black propely anymore. There where white lines between the black printed color. I did all those cleaning and deep cleaning and printhad allignments and nothing helped.
Then I stumbled upon this forum and found helpfull posts on how to solve my problem. I took my printhead out and cleaned it with a window cleaning fluid, did the same with the purge pads, until they were properly clean and did not leak any more color.
Then I started to inject the cleaning fluid in the purge pad's holes, which are connected to the tubes that lead the ink to the pads underneath the printer.
Each pad has 2 holes and if you look closely, they are not the same. One hole on each pad works perfectly and the fluid runs nice out from the tubes at the end, but the other hole is a different story. When I inject the fluid there it just backs up and fills the rubber tray, which is holding the pad. I looked at the printer and saw, that there are 4 tubes connected to the purge system, but I only see 2 ends, where the fluid comes out of.
Now my question is, is this normlan and those 2 holes are supposed not to run anywhere, or are those cloged?
I made a photo for better understanding, but can not post is since I am a new member.
Any help appreciated
