Are Canon BCI-3e Black and PGI-5 Black cartridges interchangeable?
fdm2000
I have a Canon Pixma iP 3500 using PGI-5 black pigmented cartridges and a Canon i560 using BCI-3e black pigmented cartridges. Except for the chip on the PGI-5 the two cartridges appear identical in size and configuration. I have several full BCI-3 cartridges that I would like to use in the iP 3500 if compatible.
Will the BCI-3s work with the Pixma iP 3500 without the chip?
Thanks for any insight
No, they will not fit.
You can put the chipped dye ink CLI-8 cartridges in a printer designed for the unchipped BCI-6 cartridges and they will work but the colors will be off but not the other way around.
You could put the chipped pigment black PGI-5Bk cartridge in a printer designed for the unchipped BCI-3eBk cartridge but it won't stay in place because the locking mechanisms are slightly different.
fdm2000
Thanks for the response and advice, GHWjr.
I was of the opinion that Canon had made interchangeability problemmatic - your comments confirmed it.
