- Jan 18, 2010
- Residing in Wicklow Ireland
When you print CYMK with Litho, the black was only used for highlights in the darker areas of the picture and on its own could only achieve 70 % black, not true black, but to make sure the solid areas remains very black, it was customary to use 25% cyan underneath it, that included the text also..I don't find a way to compensate this. You can darken the image or print, but the deepest black remains the same, no better d-MAX, only a darker print...
