Fried Chicken
- Sep 21, 2024
- Epson ET-8550
What is the difference between Epson 552 and Epson 114 inks?
The business region U.S, vs. Europe/EUWhat is the difference between Epson 552 and Epson 114 inks?
Komisch, ok.The business region U.S, vs. Europe/EU
I'm interested in the Longevity aspects mostly, I don't see the point of printing it to display on the wall and having it fade in 1-2 years, so your comment that the Epson OEM inks apparently perform better than most - what sort of lifespan do they have in your experience? I mostly print with Gloss and have been eyeing the 8550 for a while - already got one for my mother, but I see one on a super special at the moment and am wondering if nows the time. Just need to resolve which ink I should be using. Thanks very much for any reply.I'm currently running an ET-8550 - with dye inks - and will stay with them. But I switched various times between dye and pigment inks on various other Epson printers - like the R265 or the L800/805 or L1800 , I can report that it worked out o.k. when changing from dye to pigment inks - following a kind of similar approach as described in the farbenwerk instructions. I'm running pigment and dye inks alternatively on a small 4 color WF2010W w/o problems. I had more and longer lasting problems when trying to switch back from pigment to dye inks, incl. replacing the dampers in the printhead carriage - the cartridge like replacements in the printhead. And more effort is necessary to clean the tubes and tanks from the smallest leftovers of pigments. I would support the comment by farbenwerk to start with pigments inks directly in a new printer.
Be aware that any change as intended - swapping the inks - will void the Epson warranty so all such modifications are at your own risk.
I tested various dye inks for longevity, the best performing inks are the Epson OEM inks - 114 or 106; I couldn't find any non-OEM inks being close to OEM inks in this respect. I cannot comment on the Pigmera ETX inks by farbenwerk how they perform in regards to gamut size, black level . gloss and bronzing, there are significant differences between 3rd party pigment inks in this respect, which must always be judged in connection with particular paper types.
