- Dec 27, 2014
- Germany
- L805, WF2010, ET8550, T3100X
I cropped one image out of your sheet above, and will try to print it with a P400, just on normal paper which should be o.k. What program are you using to print these sheets ? I'm using Qimage and will create a layout 2x2 on a A4 sheet an print one at at time, then moving it to the next location.
Which format/paper settings are you using in the driver , and the print software ? it could be in a case of mismatch that the software prints leftover parts/edges on a next page , but this data may be blank, your printer just prints white in that case.
