- Dec 27, 2014
- Germany
I'm not aware of 3rd party inks with a similar UV/ozone stability like the OEM inks, I'm not so familiar with the HP printer product lines but I think to remember that there are larger format models running on dye inks and pigment inks. And the pricing for those cartridges - bigger than yours is more economical, and you are easily able to pull the ink from those cartridges, and use it as refill ink.
At a higher temperature the abs. humidity is much higher, and humidity is helping the ozone to do its work on the color molecules.
