- Jun 16, 2006
- Location
- La Verne, California
- Epson WP-4530
There have been many statements in this and other printer forums about when a Canon printer uses the black pigment ink and when it uses the black dye ink. Most of these statements are half-truths and some are absolutely false. I'm not going to bother reiterating the false or half true statements, just the truth.
The truth is that the black pigment ink is [almost] always used on plain paper--never on photo paper and the dye black ink is always used on photo paper--[almost] never on plain paper.
[NOTE: I just learned that I needed to add the word "almost" twice in the above maxim, thanks to stratman pointing this out in this post:
http://www.nifty-stuff.com/forum/viewtopic.php?pid=15097#p15097
The exception is when doing borderless printing which is not recommended on plain paper, but if you do it, the printer will use the dye black ink instead of the pigment black ink.]
Pretty simple, but there is a complication involving duplex printing. When doing duplex printing, the black pigment ink is cut to about one half of the intensity that it would normally print. Then, to make up for this decrease, the magenta and cyan inks are printed in the same area as the pigment black. The yellow and dye black are never added to the pigment black to make up the difference. NOTE: Recent tests have shown that this last statement is only true for 100% black. In fact, yellow, along with magenta and cyan, is blended for some shades of grey. Also, it doesn't matter whether the duplex printing is done automatically or manually, or whether you are doing booklet printing. And, in all cases, we are talking about duplex printing on plain paper.
Now for some background. On this forum, the main discussion can be seen by searching for "duplex pigment". One of these threads contains a reference to some very lengthy discussions on comp.periphs.printers newsgroup. Reading these will make you appreciate this forum--what a nightmare!
The printers I tested were the Canon MP760 and the iP4000, both of which use the same print head with five cartridges: the larger BCI-3e pigment black, and the smaller BCI-6 dye inks including black, yellow, cyan and magenta. I presume the same results would apply to many other Canon printers that include both types of black ink.
In order to perform the tests, I cleaned five Canon cartridges and filled them with cleaning solvent from inkjetsaver.com. After a sufficient purge, these cartridges print nothing visible on the paper which is necessary to draw correct conclusions. I then replaced one of the cartridges with a regular ink cartridge and, after a sufficient purge, printed in various modes to see if that particular ink was involved in that mode and repeated for each cartridge.
