costadinos
- Nov 16, 2012
- Location
- Cyprus
- 7900, 4900, 9890, R2000, P50
Just came up with a different approach to printing black and white using only black inks, and I thought I should share it for those interested.
Instead of using custom profiles, RIP software, or specialized all-black inksets (expensive), I simply used black ink in all the cartridges of a 1400, diluting it with different ratios with gloss optimizer for each of the six colors, and then printing normally in color using the profiles I created for the colour inkset.
I used undiluted OCP pigment black for the black channel, 60% dilution for the Cyan, 40% for the magenta, 10% for the yellow, and 2+1 parts dilution of the Cyan and Magenta for their Light counterparts.
In all honesty, I wasn't expecting the results to be that good on the first try, but here's a scan of two prints that clearly shows how well the method worked:
On the left are the prints from the all-black 1400, and on the right from an R2000, using the normal driver, and with custom profiles created with an i1 Pro (it appears there were a couple of clogged nozzles on both printers, ignore that). The top two were printed as colour (for the R2000 I simply desaturated before printing) and the bottom two were both black and white to begin with, but also printed as colour images.
Apart from that green cast that plagues the R2000 print, I can't really see any other differences, and what's more, gloss differential was completely gone (the extra GO sure had something to do with that), the print was absolutely neutral, and the tonal range didn't seem to be affected. Overall the print looked punchier.
I came up with the dilution ratios by visually examining the original inks (very rough method) and diluting black ink until the opacity looked the same. And this is where someone with maybe an optical densitometer or more willing to experiment can help improve this further; if we manage to determine the exact dilution ratio that would result in ink having the same density (or opacity in that manner) with a colour ink, then using that diluted ink and printing in colour using the profiles created for the particular inkset should result in pretty good black and white prints.
