L1800 mainboard in Epson 1430
anazoolik
L805, L1800, ET16650, ET18100
UPDATE: L1800 Mainboard arrived and in test machine all seems to work. Modified is the board for the control Buttons. There are some additional cables at bottom side.
But attention: Epson changed the board design for newer 1500W, so the new main boards are smaller (first pic CB53MAIN-B) and the L1800 (second pic CB23MAIN) won't fit in the metal case. Also the USB-Port has an other Position, so it won't fit in the plastic back cover.
:-( Connector CN1 has 4 Pins at L1800 Board, but 5 Pins at new 1500W board, so it is not possible to connect... i want to scream.
chrispol
Print Lurker
Epson 1430
Old thread ressurection, I am trying to install a L1800 board in an artisan 1430 that had the newer version of the main board, I am getting CR sensor / current errors, which I did not get when I had the original board in. Anyone have any help to offer?
